Normal Topic how can I set the grid for diagram (Read 3176 times)
Hamdy Ghanem
Apr 18th, 2009 at 8:31am
I tried this code but it did not work
  mdiagram.GridStyle = GridStyle.Lines
       mdiagram.AlignToGrid = True
       mdiagram.GridSizeX = 50
       mdiagram.GridSizeY = 50
       mdiagram.ShowGrid = True
Re: how can I set the grid for diagram
Reply #1 - Apr 20th, 2009 at 5:29am
Are you calling LoadFromXml or LoadFromFile at some point after this? This could hide the grid if the file was saved with ShowGrid = false.
Hamdy Ghanem
Reply #2 - Apr 20th, 2009 at 6:36am
I am working with
LoadFromFile
Hamdy Ghanem
Reply #3 - Apr 20th, 2009 at 6:40am
I search in the xml file
I found this
<ShowGrid>True</ShowGrid>
Reply #4 - Apr 20th, 2009 at 10:47am
What happens if you set diagram.ShowGrid = true after calling LoadFromFile?
Hamdy Ghanem
Reply #5 - Apr 20th, 2009 at 1:12pm
nothing happen
diagram is the same
Reply #6 - Apr 20th, 2009 at 6:25pm
Perhaps there is some large background node that hides the grid? If so, try setting its Brush to one with a semi-transparent color. Also check if the GridColor is different from the BackBrush color.
