Normal Topic Container Node (Read 3105 times)
muthuhamid
Container Node
Apr 19th, 2009 at 4:49pm
Hi
Am using container node, user not able to resize the container node (there is no Selection handler like other nodes). Only user has to adjust the nodes inside the container node, to make container node bigger or smaller.
Is this is the only way Container node has to be smaller or bigger? like other nodes , does container node has handler to resize the container node or not??
Pls help me in this regards
Hamid
Re: Container Node
Reply #1 - Apr 20th, 2009 at 5:24am
Try this with a different HandlesStyle value. The default for ContainerNodes is MoveOnly.
muthuhamid
Re: Container Node
Reply #2 - Apr 20th, 2009 at 12:54pm
Hi
Thanks a lot for your reply and it works fine.
And one morething i would like to ask you in Container Node is, Can i have the shape of the container node as Circle or can add my own image(Circle) to the container node.
If possible can u pls post the sample code in any case
Hamid
Re: Container Node
Reply #3 - Apr 20th, 2009 at 6:17pm
At this time this is possible only by creating a subclass of ContainerNode that overrides the Draw method.
muthuhamid
Re: Container Node
Reply #4 - Apr 21st, 2009 at 5:47am
hi
thanks and can you pls post the sample sub class pls.
Hamid
Re: Container Node
Reply #5 - Apr 22nd, 2009 at 1:55pm
For example, this class overrides the Draw method to render containers with rounded corners:
http://mindfusion.eu/_samples/RoundedContainerNode.cs
muthuhamid
Re: Container Node
Reply #6 - Apr 27th, 2009 at 8:22am
Thanks Stoyo
