Normal Topic Trigger in XAML (Read 2450 times)
Anshul
Senior Member
Trigger in XAML
Apr 20th, 2009 at 5:42am
I have created a node in a xaml file.Now I want to apply some triggers on that node to perform verious operation like NodeClicked,MouseOver,MouseEnter,OnMouseWheel etc.How can I do that ?
I have used following code in xaml.
<Window x:Class="ResourcesInXAML.Window1"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:d="clr-namespace:MindFusion.Diagramming.Wpf;assembly=MindFusion.Diagramming.Wpf"
    Title="Resources In XAML" Height="150" Width="300"
  <d:ShapeNode Bounds="100,100,100,100" Brush="Blue" Text="hello"></d:ShapeNode>
  </Window>
Re: Trigger in XAML
Reply #1 - Apr 20th, 2009 at 10:59am
<d:ShapeNode MouseEnter="OnNodeMouseEnter"  Bounds="100,100,100,100" Brush="Blue" Text="hello"></mf:ShapeNode>
worked for me.
Anshul
Senior Member
Re: Trigger in XAML
Reply #2 - Apr 20th, 2009 at 2:21pm
Hi Stoyan,
It was not my question.I want to call a trigger event on that perticular action.
I am sending you a snippet for a button control, Same i want for ShapeNode.
    Title="Resources In XAML" Height="150" Width="300">
    <Window.Resources>
	  <Style x:Key="myStyle">
		<Style.Triggers>
		    <Trigger Property="Control.IsMouseOver" Value="True">
			  <Setter Property="Control.Background" Value="Red" />
		    </Trigger>
		</Style.Triggers>
	  </Style>
    </Window.Resources>
    <StackPanel Margin="30">
	  <Button Style="{StaticResource myStyle}"
		Width="200" Height="40">
		ASP Alliance
	  </Button>
    </StackPanel>
</Window>
Re: Trigger in XAML
Reply #3 - Apr 21st, 2009 at 9:37am
Seems events cannot be attached through styles. The Style property is defined in FrameworkElement, while DiagramItem inherits UIElement, and does not support it.
