Normal Topic Node image. (Read 1897 times)
maor
Node image.
Apr 20th, 2009 at 1:53pm
i have an image that i want to set to the shape node in my diagram.
i want to know if you code is duplicate the image for each node or all the nodes are use the same pointer?
Thanks.
Re: Node image.
Reply #1 - Apr 20th, 2009 at 6:58pm
The image is not cloned when you assign it to a node. All nodes will reference the same image object.
maor
Re: Node image.
Reply #2 - Apr 21st, 2009 at 7:21am
Great!
