Normal Topic Drag Drop when zoomedin/out (Read 2763 times)
Gautham
Apr 26th, 2012 at 10:33am
I'm using version 2.0.0.21207 of mind fusion diagram, i've have a problem when adding items to the diagram when the diagram is zoomed in/out. These items are getting added by draging and droping from another control. The problem is that the positions of the items are offset from the original drop position, depending on the zoom factor.
This can be reproduced in the sample bundled with mind fusion silverlight installer "Drag Drop", by changing the zoom factor of the target diagram. And also by the sample attached here (but done using rad drag drop manager). Is there any work around for this ?
Gautham
Re: Drag Drop when zoomedin/out
Reply #1 - Apr 26th, 2012 at 11:46am
It should work correctly with a zoomed diagram if you use MouseEventsArgs.GetPosition(diagram.documentPlane) instead of MouseEventsArgs.GetPosition(diagram).
Gautham
Reply #2 - May 15th, 2012 at 12:53pm
Thanks it works
