Normal Topic Draw nodes in the same locations (Read 2608 times)
Selim
Apr 23rd, 2012 at 11:42pm
It seems every time Layout.Arrange gets called, the nodes get placed in an arbitrary position. Is there a way to specify the nodes locations so it does not always randomize their positions?
Thank you
Re: Draw nodes in the same locations
Reply #1 - Apr 24th, 2012 at 5:51am
What layout class are you using? The ones that include randomization usually expose Randomize and/or RandomSeed properties - set Randomize to false or RandomSeed to a fixed value to get the same layout at each call to Arrange. If you are using SpringLayout, you can set node.LayoutTraits[SpringLayoutTraits.Frozen] to keep a node at its current position.
Selim
Reply #2 - Apr 24th, 2012 at 2:44pm
That did it!
Thanks a lot
