Normal Topic Modify Link after swimlane layout (Read 4525 times)
binuvc
Apr 27th, 2012 at 9:40am
Once we apply the swimlane layout, we are not able to modify the link beginconnectionpoint and endconnectionpoint. It is allowing to modify the intermediate control points of the link. Begin and end connectionpoints are reverting back to the previous points itself.
Following is the code that we use to apply swimlane layout
    SwimlaneLayout layout = new SwimlaneLayout();
            layout.Anchoring = Anchoring.Ignore;
            layout.CollapseEmptyLanes = false;
            layout.CompactNodes = false;
            layout.Direction = MindFusionLayout.Direction.Straight;
            layout.KeepGroupLayout = false;
            layout.KeepLaneSizes = true;
            layout.LaneDistance = 150;
            layout.NodeDistance = 50;
            layout.Orientation = MindFusionLayout.Orientation.Horizontal;
            layout.Margins = new Size(
                     diagramLite.LaneGrid.GetRowHeaderBounds().Width,
                     diagramLite.LaneGrid.GetColumnHeaderBounds().Height);
            layout.Arrange(diagramLite);
            var rect = diagramLite.LaneGrid.GetColumnHeaderBounds();
            rect.Union(diagramLite.LaneGrid.GetRowHeaderBounds());
            diagramLite.Bounds = rect;
Please advice.
BinuVC
« Last Edit: Apr 27th, 2012 at 11:17am by binuvc »
Re: Modify Link after swimlane layout
Reply #1 - Apr 27th, 2012 at 1:24pm
I am not able to reproduce this. Can you attach a small sample illustrating it?
binuvc
Reply #2 - Apr 27th, 2012 at 3:14pm
Please find the attached sample.
Also included in the project is a txt file listing the issues noted.
I have added 3 issues that have been posted separately in the forum.
1) if all the lanes in a diagram are empty, layout.arrayge throws error.
2) empty lanes dissappearing on applying layout
3) not able to move links once layout is applied
Please advice.
BinuVC
SilverlightApplication2.zip (Attachment deleted)
Reply #3 - Apr 27th, 2012 at 3:34pm
1) This is a bug. We will fix it.
2) This is by design and can be worked around using one of the suggestions from this thread.
3) It appears that the layout sets Diagram.RoutingOptions.Anchoring to Anchoring.Reassign which causes subsequent modifications of the link end points to reset to the nearest anchor. To resume the link modification behavior set this property to Anchoring.Ignore after the layout has been applied. This is something we will likely fix too to avoid side effects caused by the layout.
binuvc
Reply #4 - Apr 27th, 2012 at 4:28pm
Many Thanks !!
Finally it is working!!
BinuVC
