Normal Topic How can I set TableNode's CaptionColor? (Read 1612 times)
wangzh
Apr 27th, 2009 at 7:39am
I using the net diagram in JavaApplet mode. I want to set TableNode CaptionColor Properties in JavaScript on the client-side.
I'm found the TableNode.setCaptionColor method need an Color parameter,But i donot know how create an Color object?
Can you give me an example?
thanks!
Re: How can I set TableNode's CaptionColor?
Reply #1 - Apr 27th, 2009 at 9:06am
You could call ScriptHelper.createSolidBrush(...).getColor().
