Normal Topic Pathfinder - Shortest path (Read 1632 times)
muthuhamid
Apr 27th, 2009 at 9:14am
When i am trying to find the shortest path between two selected nodes am getting the following Exception Error
{"Value cannot be null.
Parameter name: value"}
The scenario behind this error is :
My starting node(From node) is inside the Container Node and the end node(To node) is out side of the Container.
Code am using is as follows
try
Dim pFinder As New PathFinder(Me._Doc, True)
Dim tPath As Path = pFinder.FindShortestPath(sServer, dServer)
Catch ex As Exception
End Try
It works fantastic if I try with from node and to node is not in the container.
Can You pls help me in this regards.
Hamid
Re: Pathfinder - Shortest path
Reply #1 - Apr 27th, 2009 at 12:55pm
This should work with version 5.2.1. What version are you using now?
muthuhamid
Reply #2 - Apr 27th, 2009 at 1:16pm
Yeah...
Thanks a lot .
It works with 5.2.1.
