Normal Topic Disable Right Click on Shape Node. (Read 2853 times)
SandeepGowda
Apr 28th, 2009 at 11:10am
Can you help me to Disable the Right Click on Selected Shape Node.
regards
Sandeep
Re: Disable Right Click on Shape Node.
Reply #1 - Apr 28th, 2009 at 11:27am
If you need to disable cancelling the operation upon right-click, set DiagramView.RightButtonActons = None.
SandeepGowda
Reply #2 - Apr 28th, 2009 at 11:48am
Stoyo,
I have PopupMenus added for each Task,which have to be disabled.
But i am not able to find the  set DiagramView.RightButtonActons method as such. Can you please help me
regards
Sandeep
Reply #3 - Apr 28th, 2009 at 11:51am
That has nothing to do with context menus. You probably show them from the NodeClicked event handler.
Necroman
Reply #4 - Oct 2nd, 2009 at 9:29am
I've got similar question. Is it possible to preserve the diagramView.RightButtonActions = MouseButtonActions.Pan; behavior and also to handle rightclicks for showing context menu on diagram/nodes/cells? Currently I handle the Diagram_CellClicked event, but it has been never fired on right click with this setting.
Reply #5 - Oct 2nd, 2009 at 2:39pm
Seems we'll have to rearrange the mouse-up handler a bit to enable this. We'll do that next week.
