Normal Topic GridLayout multiple rows (Read 1507 times)
jmquinlan
Apr 29th, 2009 at 10:22am
I'm using a grid layout to layout the nodes inside a container node. The setup is something like below:
1 container node contains
8 container nodes that each contain
3 to 4 table nodes interlinked
when i layout the contents of the primary container node using the grid layout, the layout places all container nodes horizontally from left to right in the same row.
it does not create multiple container rows of nodes eg.
this is what i get,
containernode
[container] [container] [container] [container]
instead of what i want.
containernode
how can I make the layout use multiple rows? below is my layout configuration:
    private void LayoutDiagram()
            this.Cursor = Cursors.WaitCursor;
            GridLayout newLayout = new GridLayout();
            newLayout.Anchoring = Anchoring.Keep;
            newLayout.RandomSeed = 5;
            newLayout.Iterations = 15;
            newLayout.GridSize = 15;
            DiagramItemCollection diagramItems = new DiagramItemCollection();
            if (m_diagram.Selection.Nodes.Count > 0)
                newLayout.StartNode = m_diagram.Selection.Nodes[0];
                diagramItems = m_diagram.Selection.Items;
                foreach (DiagramItem item in diagramItems)
                    if (item.GetType() == typeof(ProcessNode))
                        ArrangeSubItems(newLayout, item as ContainerNode);
            m_diagram.ResizeToFitItems(20);
            this.Cursor = Cursors.Default;
Maybe I've missed some diagram initialisation to prevent it resizing the diagram or somethins.
anyways any suggestions would be usefull cheers guys.
Re: GridLayout multiple rows
Reply #1 - Apr 29th, 2009 at 1:48pm
If there are no links between the containers, it might process them as four separate graphs. Try setting GridLayout.SplitGraph = false, or GridLayout.MultipleGraphsPlacement = MinArea.
jmquinlan
Reply #2 - May 18th, 2009 at 4:37pm
yes that helped alot the layout is working really well now
