Normal Topic Need Diffrent behavior of diagram simultanously (Read 1337 times)
Bala
Apr 30th, 2009 at 12:06pm
In my application I need to Implement different behavior of diagram at same time.
I need Modify behavior at intialization and after that I need Custom and DrawLinks.
Can I have multiple behavior simultanously?
Bala
Re: Need Diffrent behavior of diagram simultanousl
Reply #1 - Apr 30th, 2009 at 12:36pm
You could implement a custom class derived from BehaviorBase and assign its instance to Diagram.CustomBehavior. You might as well dynamically set the Behavior property to one of the built-in values in response to the MouseMove event.
