Normal Topic style of selection (Read 2842 times)
tzippy
style of selection
Apr 30th, 2009 at 1:54pm
When I select an item in the diagram there are squares around the Item.
How can I set the visibility of these squares?
I don't want to see them, but I want to use the selection of the diagram.
Re: style of selection
Reply #1 - Apr 30th, 2009 at 2:58pm
Set HandlesStyle = Invisible.
tzippy
Reply #2 - May 3rd, 2009 at 6:49am
The property wasn't found in the diagram.
tzippy
Reply #3 - May 4th, 2009 at 6:31am
I found it  Smiley
tzippy
Reply #4 - May 10th, 2009 at 7:14am
It works well with nodes,
but not with links Sad
Reply #5 - May 10th, 2009 at 8:51am
Links support only the SquareHandles, DashFrame and Custom styles. You could set HandlesStyle = Custom for links and then just return from the DrawAdjustmentHandles event handler.
