Normal Topic Version 1.0.3 (Read 3349 times)
maor
Version 1.0.3
May 3rd, 2009 at 8:06am
Thanks for the new version.
there are 2 things we need.
Expand button:(+\-)
1. In case there is no child for node - its still show the expand button.
2. When user hover with the mouse on the expand button its show the shape toolTip (i think its not good behaviour).
Thanks.
Re: Version 1.0.3
Reply #1 - May 4th, 2009 at 9:09am
Can't you set Expandable = false to hide the button when a node doesn't have children? The control also supports custom behavior for the collapse/expand button (through the ExpandButtonAction property and some event handling), so we prefer the button visibility to be determined by the property value, rather than the number of child nodes.
maor
Re: Version 1.0.3
Reply #2 - May 4th, 2009 at 9:12am
"so we prefer the button visibility to be determined by the property value, rather than the number of child nodes."
how i do it? can you add example please?
Re: Version 1.0.3
Reply #3 - May 4th, 2009 at 4:04pm
This version makes the DiagramNode.Expandable property public Wink
https://mindfusion.eu/_beta/DiagramLite103.zip
It also adds the LayeredLayout.KeepRootPosition property you requested. It works only if you set some node as LayeredLayout.Root (while TreeLayout is able to select the root node automatically in most cases).
maor
Re: Version 1.0.3
Reply #4 - May 5th, 2009 at 7:56am
Stoyo, Thank you very much!
(there is any solution when you hover on the collpase button and see the tool tip of the shape?)
Maor
Re: Version 1.0.3
Reply #5 - May 8th, 2009 at 12:27pm
Hi Maor,
This version does not display tooltips for the +/- buttons:
maor
Re: Version 1.0.3
Reply #6 - May 10th, 2009 at 7:30am
Great!
