Normal Topic Wrong Anchor points when using DiagramNodeAdapter (Read 2549 times)
lex
May 3rd, 2009 at 3:17pm
I have encountered a problem when hosting a custom UserControl inside DiagramNodeAdapter. Some of the anchor points appear inside the node upon UserControl UI.
The printscreen image was sent to support email.
Re: Wrong Anchor points when using DiagramNodeAdap
Reply #1 - May 4th, 2009 at 12:09pm
What does the Xaml for the user controls look like? We have some code that examines the visual tree of the control to decide where to place the links end points, and apparently it fails with your controls. Does the same thing happen if you set Dynamic = true for some link and move its connected node around?
