Normal Topic Layered Layout (Read 1741 times)
maor
Layered Layout
May 4th, 2009 at 8:00am
I need important property for layered layout (appear in tree layout).
option to set the root position (in tree - keepRootPosition).
also the link that draw in large graph is not connected to the middle of the shape.(send you attachment)
Re: Layered Layout
Reply #1 - May 4th, 2009 at 9:02am
We can implement KeepRootPosition for the case when there is just one root node, but what should happen if there are more than one roots? The only way to implement it we could think of is to keep the position of the node set as LayeredLayout.Root, and let the algorithm assign the positions of other roots as it sees fit.
maor
Re: Layered Layout
Reply #2 - May 4th, 2009 at 9:06am
when i set Layered.Root.Bounds its not work like the treeLayout.
I search for behaviour like the tree layout:
1. keepRootPosition
2. Root.Bounds = ...
