Normal Topic Blue square of selection (Read 3153 times)
tzippy
May 4th, 2009 at 10:20am
I want to remove the square which is drawn when I drag the mouse on the diagram.
Although the multi-selection is disabled, the square is still shown.
How can I do it?
Thanx
Re: Blue square of selection
Reply #1 - May 4th, 2009 at 12:24pm
Create a class derived from BehaviorBase, override StartDraw and always return null. Assign its instance to Diagram.CustomBehavior, and the only thing the user should be able to do is select items by clicking on them.
tzippy
Reply #2 - May 4th, 2009 at 1:31pm
Can you send me an example please?
I don't know what about the constructor and the mathod SetMouseCursor etc.
Reply #3 - May 4th, 2009 at 2:35pm
class MyBehavior : BehaviorBase
	public MyBehavior(Diagram diagram) : base(diagram) {}
	public override InteractionState StartDraw(Point point) { return null; }
	public override CursorHint SetMouseCursor(Point point, out bool startInteraction)
		startInteraction = false; return CursorHint.Pointer;
tzippy
Reply #4 - May 5th, 2009 at 6:42am
Thank's,
But now there is no selection to the diagram.
(I want selection by clicking on item).
Reply #5 - May 5th, 2009 at 8:16am
You could change the selection in response to the NodeClicked event, or do this in the Behavior.StartDraw override:
DiagramItem item = Diagram.GetItemAt(point, true);
if (item == null || Diagram.RaiseSelecting(item, point))
	Diagram.Selection.Change(item);
tzippy
Reply #6 - May 5th, 2009 at 8:46am
It works  Smiley
