Normal Topic Text in the diagram (Read 1366 times)
tzippy
Text in the diagram
May 6th, 2009 at 4:47am
Is there any option to put text in the diagram, not in a node or link?
Re: Text in the diagram
Reply #1 - May 6th, 2009 at 8:10am
There isn't. What you can do is to create a ShapeNode, assign the text to it, enable its Transparent, Locked and IgnoreLayout properties, and disable its Obstacle property.
