Normal Topic Prevention of Node deletion in ImageMap Mode (Read 4137 times)
jcollins@scires
May 6th, 2009 at 1:56pm
Hello Stoyan, It seems I can prevent deleting of nodes in javaapplet mode by handling the nodedeleting javascript event. Is there anything like this for imagemap mode? How can I prevent deletion of a node in ImageMap? Thanks.
jay
Re: Prevention of Node deletion in ImageMap Mode
Reply #1 - May 7th, 2009 at 10:32am
Hi Jay,
Version 3.0.1 adds support for the Deleting, Creating and Modifying script properties in ImageMap mode. The last build we sent you should let you handle them like this:
<... NodeDeletingScript = "onNodeDeleting">
function onNodeDeleting(sender,args)
     args.set_cancel(!confirm('Are you sure?'));
jcollins@scires
Reply #2 - May 7th, 2009 at 2:51pm
Hmm....For some reason, it does not seem to be working for me. The latest I downloaded was this version: https://mindfusion.eu/_beta/netdiag103beta.zip
here is the code:
<head id="Head1" runat="server">
    <title>Untitled Page</title>
    <script type="text/javascript" language="javascript">
       function onNodeDeleting(sender, args) {
    </script>
</head>
<body style="background-color:#CCCCCC">
    <form id="form1" runat="server">
    <asp:ScriptManager runat="server" ID="scriptmanager" AsyncPostBackTimeout="300">
    </asp:ScriptManager>
    <asp:UpdatePanel runat="server" ID="up1">
       <ContentTemplate>
           <ndiag:DiagramView runat="server" DelKeyAction="DeleteSelectedItems" ID="diagView" AutoScroll="true" Height="500px" Width="500px"  ClientSideMode="ImageMap"
              NodeDeletingScript="onNodeDeleting">
               <Diagram AllowSelfLoops="false" TextColor="White" DefaultShape="Rectangle" AutoResize="RightAndDown" LinkCrossings="Arcs"
                RouteLinks="true"  />
           </ndiag:DiagramView>
           <ndiag:InteractivityExtender ID="InteractivityExtender1" TargetControlID="diagView" runat="server" />
           <asp:Button runat="server" ID="btntest" Text="test" />
       </ContentTemplate>
    </asp:UpdatePanel>
    </form>
</body>
jay
Reply #3 - May 8th, 2009 at 7:27am
You must also set EnableItemsDOM=true for these events to work in ImageMap mode.
jcollins@scires
Reply #4 - May 8th, 2009 at 2:19pm
Hey Stoyan. I think we are getting closer. I am now getting this javascript error:
Microsoft JScript runtime error: 'JSON' is undefined
any ideas? Thanks
jay
Reply #5 - May 8th, 2009 at 2:50pm
Our developer played with the built-in JSON parser of IE8, so this won't work in older IE versions. We'll upload a version that does not use it in awhile.
Reply #6 - May 8th, 2009 at 4:05pm
The assemblies from the link below should work correctly. The required change was done in a .js file embedded as a resource, so this version might have the future-date problem again...
https://mindfusion.eu/_beta/netdiag301_json.zip
