Normal Topic Query regarding Zooming on Node (Read 1896 times)
Bala
May 7th, 2009 at 7:03am
I want to perform Zoom-In on node while mouse enter. See the code below. I am facing two problem in this.
1. I want to zoom according to the zoomfactor of the diagram. Let’s say if zoomfactor is 100 than node should not be zoomed, if zoom factor is 40 than node should be zoomed 2.5 times of its original dimension.
2. I have applied double animation for the same and put AutoReverse=true.
I want some delay in autoreverse. For ex. - if time for zooming is 3ms than I want get autoreverse should happen after a time delay say 5 sec.
 TransformGroup tg = new TransformGroup();
		tg.Children.Add(originalTransform);
		tg.Children.Add(scale);
		sourceNode.RenderTransform = tg;
		var xa = new DoubleAnimation(1, 2, new Duration(new TimeSpan(0, 0, 0, 0, 500)));
		var ya = new DoubleAnimation(1, 2, new Duration(new TimeSpan(0, 0, 0, 0, 500)));
		if (diagram.FindName("mouseEnter") != null)
		    diagram.UnregisterName("mouseEnter");
		diagram.RegisterName("mouseEnter", scale);
		Storyboard.SetTargetName(xa, "mouseEnter");
		Storyboard.SetTargetProperty(xa, new PropertyPath("ScaleX"));
		Storyboard.SetTargetName(ya, "mouseEnter");
		Storyboard.SetTargetProperty(ya, new PropertyPath("ScaleY"));
		var sb = new Storyboard();
		sb.AutoReverse=True;
		sb.Children.Add(xa);
		sb.Children.Add(ya);
		sb.Begin(diagram);
		sb.Stop();
Can anybody help me on this?
Bala
Anshul
Senior Member
Re: Query regarding Zooming on Node
Reply #1 - May 9th, 2009 at 12:31pm
Can anybody give reply for the above post?
Reply #2 - May 11th, 2009 at 9:36am
for 1
private void testZoomAnimation()
	var sourceNode = d.Factory.CreateShapeNode(30, 30, 50, 50);
	var originalTransform = sourceNode.RenderTransform;
	var diagram = d;
	diagram.ZoomFactor = 40;
	double zoom = 100 / diagram.ZoomFactor;
	var scale = new ScaleTransform() { CenterX = sourceNode.Bounds.Width / zoom, CenterY = sourceNode.Bounds.Height / zoom};
	DoubleAnimation xa = new DoubleAnimation(1, zoom, new Duration(new TimeSpan(0, 0, 0, 0, 500)));
	DoubleAnimation ya = new DoubleAnimation(1, zoom, new Duration(new TimeSpan(0, 0, 0, 0, 500)));
	var sb = new Storyboard { AutoReverse = true, Children = { xa, ya } };
	sourceNode.MouseEnter += (s, e) => { sb.Begin(diagram); };
Reply #3 - May 11th, 2009 at 10:07am
for 2 use key frames, with AutoReverse = false:
var xa = new DoubleAnimationUsingKeyFrames{
	Duration = TimeSpan.FromSeconds(3),
	KeyFrames = {
		new LinearDoubleKeyFrame(zoom),
		new LinearDoubleKeyFrame(zoom, KeyTime.Uniform),
		new LinearDoubleKeyFrame(1, KeyTime.Uniform),
var ya = new DoubleAnimationUsingKeyFrames{
	Duration = xa.Duration,
	KeyFrames = xa.KeyFrames
