Normal Topic No no apparent reason, this error has started... (Read 2404 times)
lollipop
May 10th, 2009 at 3:40pm
Error41'Could not load file or assembly 'Calendar, Version=4.2.1.19730, Culture=neutral, PublicKeyToken=9bbcdceda2685d38' or one of its dependencies. Invalid pointer (Exception from HRESULT: 0x80004003 (E_POINTER))'
All references are there, I only have one install of planner, full paid up version. Just in case, I deleted them all, and re-referenced them.
Re: No no apparent reason, this error has started.
Reply #1 - May 11th, 2009 at 6:01am
What happens when you create a new application and add the Calendar control to it?
lollipop
Reply #2 - May 11th, 2009 at 8:05pm
I can add a new form to the project and drop a control and this renders ok.
The problem form has a stack load of controls, and I'ld like to save it...
lollipop
Reply #3 - May 11th, 2009 at 10:23pm
I cleared out my temp for winforms
C:\Users\[profile name]\AppData\Local\Temp
Then is compiled and VS could render the page.
