Normal Topic Require DoubleAnimation on ChildNode (Read 1854 times)
Bala
May 11th, 2009 at 8:24am
I have some ShapeNode in my application.I have attached a labelNode(ShapeNode) in each of the mainNode using labelNode.AttachTo(mainNode, AttachToNode.BottomCenter);.
Now I have applied double animation in mainNode, but by this only mainNode gets animation.I want, this should be apply in child node(labelNode) also.
Is there any way or property by which double animation can be performed on both the nodes simultanously?
Bala
Re: Require DoubleAnimation on ChildNode
Reply #1 - May 11th, 2009 at 1:54pm
You should run a second animation for the labelNode. If it has the same center as the one for the parent node, the nodes will scale uniformly; but since the center is given in coordinates relative to the node, you will have to use a separate DoubleAnimation instance.
Bala
Reply #2 - May 11th, 2009 at 2:39pm
I have already done this,But problem is that I can easily see that there are two nodes in which zooming is performed.I want a single look of zoom for both the node.
Reply #3 - May 11th, 2009 at 2:53pm
You haven't set correctly the ScaleTransform center if you can see a difference.
