Normal Topic ZTop doesnt work (Read 2566 times)
jmquinlan
ZTop doesnt work
May 11th, 2009 at 11:32am
hello,
I'm using ZTop on a newly created table node to try to bring it to the front. The location should place it smack bang ontop of a couple of container nodes.
eg.
containernode
     Containernode
       TableNode1--->tablenode2
I attempt to create a node which should place it near tablenode1 and tablenode 2. It appears behind the container nodes.
I call ZTop after its initialisation and it still ends up behind the containers.
regards
Jm
Re: ZTop doesnt work
Reply #1 - May 11th, 2009 at 11:54am
Call it after the node has been added to the diagram:
node = new TableNode(...);
diagran.Nodes.Add(node);
node.ZTop();
It's kind of a standalone object before that and knows nothing about the diagram's Z order.
jmquinlan
Reply #2 - May 11th, 2009 at 1:59pm
It is being called after, I think I tracked it down to the container node was selected.
It seems that if you have a selected containernode above the table node you call ZTop on it will not move the table node forward.
regards
Reply #3 - May 11th, 2009 at 2:05pm
I think the selection state shouldn't matter once you add the item, but that might be a refresh problem; what happens if you call diagram.Invalidate() after ZTop? You might also try using SelectionOnTop = false.
