Normal Topic SaveToString and LoadFromString - unsupport format (Read 1935 times)
darrenwwwa
May 12th, 2009 at 9:23am
The base16 and bast64 format for SaveToString just does not work. It returns nothing. The SML and CompressedXML format works fine.
Also, the LoadFromString give me the error 'Unsupported file format'.
I pass it the string derived from XML or CompressedXml and I get the error.
Any ideas why this is? There is nothing on the forums about this.
I am using the trial version of WPFDiagram.
Please help.
Here is the code I have been testing:
string test1 = diagram.SaveToString(SaveToStringFormat.Base16, false);
            string test2 = diagram.SaveToString(SaveToStringFormat.Base64, false);
            string test3 = diagram.SaveToString(SaveToStringFormat.Xml, false);
            string test4 = diagram.SaveToString(SaveToStringFormat.CompressedXml, false);
diagram.LoadFromString(test4);
The xaml code:
<ScrollViewer Grid.Row="1" Grid.Column="0" Margin="0,0,0,0" Focusable="False" HorizontalScrollBarVisibility="Visible" VerticalScrollBarVisibility="Visible">
            <diagram:Diagram x:Name="diagram"
                       ShowAnchors="Auto"
                       BackBrush="LightGray"
                       AlignToGrid="True"
                       GridSizeX="15"
                       GridSizeY="15"
                       ShapeHandlesStyle="HatchHandles3"
                       ShowGrid="True"
                       GridColor="Black"
                       Behavior="DrawLinks"
                       ShapeBrush="DeepSkyBlue"
                       DragDrop.DragOver="diagram_DragOver"
                       DragDrop.Drop="diagram_Drop"
                       LinkHeadShape="Triangle"
                       NodeActivated="diagram_NodeActivated"
                       NodeDeactivated="diagram_NodeDeactivated"
                       NodeDeleting="diagram_NodeDeleting"
                       NodeDeleted="diagram_NodeDeleted"
                       NodeClicked="diagram_NodeClicked"
                       LinkCreated="diagram_LinkCreated"
                       LinkDeleting="diagram_LinkDeleting"
                       LinkClicked="diagram_LinkClicked"
                       AllowDrop="True" HorizontalContentAlignment="Stretch" />
        </ScrollViewer>
<diagram:NodeListView x:Name="shapeList" Grid.Row="0" BorderBrush="Transparent" BorderThickness="0">
                <diagram:TableNode x:Name="shapeKbaTable" ConnectionStyle="Both"
                                   ColumnCount="2" RowCount="4" Bounds="2,2,50,50"
                                   Brush="Red" diagram:NodeListView.Label=" KBA Element "
                                   Style="RoundedRectangle" Grid.IsSharedSizeScope="True"
                                   IgnoreLayout="False" Obstacle="False" CellFrameStyle="None" CellCustomDraw="None" AllowDrop="True" />
            </diagram:NodeListView>
Re: SaveToString and LoadFromString - unsupport fo
Reply #1 - May 12th, 2009 at 10:10am
I think our developers have recently fixed some problems in LoadFromstring. Please try it with the latest build of the control:
https://mindfusion.eu/_beta/wpfdiag_customlayers.zip
Base16 and Base64 are not supported, and are no longer available in that enumeration.
darrenwwwa
Reply #2 - May 12th, 2009 at 11:10am
That was the problem. Thanks for the new .dlls.
