Normal Topic Nodes are getting Trespassed (Read 3694 times)
ramesh.Kurmilla
May 12th, 2009 at 11:26am
  When linking 2 nodes, links are not getting auto routed. Rather it tresspasses the nodes in between. Following is the code snippet and output thereof. Please advice.
XAML.CS CODE
using System;
using System.Collections.Generic;
using System.Linq;
using System.Net;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Animation;
using System.Windows.Shapes;
using System.Windows.Browser;
using System.Windows.Data;
using MindFusion.Diagramming.Silverlight.Layout;
using MindFusion.Diagramming.Silverlight;
using System.Xml.Linq;
using System.Windows.Media.Imaging;
using System.Windows.Resources;
namespace SampleApp8
    public partial class Page : UserControl
       public Page()
           InitializeComponent();
           MindFusion.Diagramming.Silverlight.ShapeNode node1 = diagram.Factory.CreateShapeNode(100,0, 60, 60);
           node1.Text = "One";
           //node1.Obstacle = false;
           MindFusion.Diagramming.Silverlight.ShapeNode node2 = diagram.Factory.CreateShapeNode(200,0, 60, 60);
           node2.Text = "Two";
           node2.Obstacle = false;
           MindFusion.Diagramming.Silverlight.ShapeNode node3 = diagram.Factory.CreateShapeNode(300,50, 60, 60);
           node3.Text = "Three";
           node3.Obstacle = false;
           node3.Opacity = 100;
           MindFusion.Diagramming.Silverlight.ShapeNode node4 = diagram.Factory.CreateShapeNode(500, 0, 60, 60);
           node4.Text = "Four";
           diagram.Factory.CreateDiagramLink(node1,node2);
           diagram.Factory.CreateDiagramLink(node1,node3);
           //diagram.Factory.CreateDiagramLink(node4, node3);
           //diagram.Factory.CreateDiagramLink(node3, node2);
           //diagram.Factory.CreateDiagramLink(node2, node4);
           diagram.DynamicLinks = true;
           diagram.ShowAnchors = ShowAnchors.Auto;
           diagram.RoutingOptions.Anchoring = Anchoring.Keep;
           diagram.RoutingOptions.CrossingCost = 200;
           diagram.RoutingOptions.NodeVicinityCost = 40;
           diagram.RouteLinks = true;
           //TreeLayout tree = new TreeLayout();
           //tree.Root = diagram.Nodes[0];
           //tree.Direction = TreeLayoutDirection.LeftToRight;
           //tree.LinkStyle = TreeLayoutLinkType.Cascading3;
           //tree.LevelDistance = 400;
           //tree.NodeDistance = 40;
           //tree.Arrange(diagram);
           GridLayout newLayout = new GridLayout();
           newLayout.Anchoring = Anchoring.Keep;
           newLayout.RandomSeed = 5;
           newLayout.Iterations = 15;
           newLayout.GridSize = 15;
           newLayout.Root = diagram.Nodes[0];
XAML CODE
<UserControl x:Class="SampleApp8.Page"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:d="clr-namespace:MindFusion.Diagramming.Silverlight;assembly=DiagramLite"
    Width="800" Height="800">
    <Grid x:Name="LayoutRoot" Background="White">
       <d:Diagram x:Name="diagram" Width="1000" Height="1650"
                      ShowGrid="False"
                      Background="#FFE0E0E0"
       </d:Diagram>
    </Grid>
</UserControl>
Re: Nodes are getting Trespassed
Reply #1 - May 12th, 2009 at 12:12pm
RouteLinks specifies the default value for the AutoRoute property of newly created links, so setting diagram.RouteLinks = true after the links are created does not have any effect.
ramesh.Kurmilla
Reply #2 - May 12th, 2009 at 1:54pm
hi
i have commneted the line  " diagram.RouteLinks = true;" in my application. but not any effect.
plz help me in this issue..!!
Ram..
Reply #3 - May 12th, 2009 at 2:08pm
You should not comment it out but set it before the links are created.
ramesh.Kurmilla
Reply #4 - May 13th, 2009 at 5:50am
i have used this peace of codebut it is not routing the links:
if possible plz send me sample of code to routing the links when node beteen them.
Page.xaml:
                      ShowGrid="False"
                      Background="#FFE0E0E0" RouteLinks="True" DynamicLinks="True" >
       </d:Diagram>
    </Grid>
</UserControl>
page.xaml.cs;
MindFusion.Diagramming.Silverlight.ShapeNode node1 = diagram.Factory.CreateShapeNode(100, 0, 60, 60);
           node1.Text = "One";
           MindFusion.Diagramming.Silverlight.ShapeNode node2 = diagram.Factory.CreateShapeNode(200, 0, 60, 60);
           node2.Text = "Two";
           MindFusion.Diagramming.Silverlight.ShapeNode node3 = diagram.Factory.CreateShapeNode(300, 50, 60, 60);
           //node3.Obstacle = false;
           node1.Text = "One";
           node2.Text = "Two";
           diagram.Factory.CreateDiagramLink(node1, node2);
           diagram.Factory.CreateDiagramLink(node1, node3);
link is crossing the nodes.
THanks
Ram...
Reply #5 - May 13th, 2009 at 9:08am
It seems at this time new links are auto-routed only when created interactively. Try calling the link.Route() method after creating a link.
ramesh.Kurmilla
Reply #6 - May 13th, 2009 at 1:00pm
thanks stoyo
got it..!!!
Ram
