Normal Topic Links are overlapping try to connect nodes (Read 2944 times)
ramesh.Kurmilla
May 13th, 2009 at 11:33am
hi Stoyn
we have a problem like:
e.g: Assume below each number is "Node", when i try to connect 1 to 9 and 1 to 6,  the links are overlapping. is there any property to didn't overlap links when try to connect nodes.
1 2 3
4 5 6
7 8 9
plz help me to solve the issue.
if there is a part of code plz share me...
Ram
Re: Links are overlapping try to connect nodes
Reply #1 - May 13th, 2009 at 12:38pm
Do you mean the paths found by the auto-routing function overlap?
ramesh.Kurmilla
Reply #2 - May 13th, 2009 at 12:58pm
Yes,Stoyo.
When link moves from  node 1 to 9 and 3 to 7. links are overlapped between the nodes 2 and 5.
plz help me.
Ram.
Reply #3 - May 13th, 2009 at 1:19pm
Try using cascading links (DiagramLink.Style = Cascading). RoutingOptions.CrossingCost is considered only for such links. Also the distance between nodes should be at least four times the routingOptions.GridSize for there to be enough space for the links to be placed apart.
ramesh.Kurmilla
Reply #4 - May 14th, 2009 at 5:12am
yes, if we place the distance between the nodes, links are not overlapping..
Thank a ton..stoyo!!!
Regards
Ram
