Normal Topic Remove child node from container callback (Read 2509 times)
jmquinlan
May 13th, 2009 at 11:56am
ContainerChildRemoved event does not fire when you delete a node from within a container.
not sure if this is design or not.
as a work around I respond to the node deleted event and then call the ContainerChildRemoved.
regards
MUDO
Re: Remove child node from container callback
Reply #1 - Dec 29th, 2009 at 2:15pm
Hi guys!
I have the same problem! Is there an idea if its going to be changed or its not bug or ... ?
Im waiting... Smiley
...MUDO...
