Normal Topic Cant get Server Side onnodeclicked event to work (Read 1412 times)
Lenny
May 13th, 2009 at 5:53pm
Hi all,
I am evaluationg the NetDiagram for ASP.Net product and really like it, however i cant seem to get the onnodeclicked event to fire off. I followed the instructions that came with the help saying to goto the detail view, select the diagramview control, go under events and click on NodeClicked. When i do just as in the help a new event handelr is created in the code behind and i then tried to update the text property of a label to a hard coded string. the problem is it never fires off. I tried placing a break point on the handler and confirmed it is not firing off or not linked correctly. i placed a textchange event on a textbox on the same page and was able to change the label and a breakpoint shows that event was handled.
Any suggestions?
Here is a snippet of the aspx and the code behind...
<ndiag:DiagramView ID="diagView" runat="server" Height="500px" Width="500px"
ClientSideMode="JavaApplet" onnodeclicked="diagView_NodeClicked2"/>
protected void diagView_NodeClicked2(object sender, NodeEventArgs e)
Label1.Text = "click";
Re: Cant get Server Side onnodeclicked event to wo
Reply #1 - May 13th, 2009 at 6:31pm
In JavaApplet mode, the events are raised on the cilent side. You should set the NodeClickedScript to the name of a JavaScript function that should handle the event. The DiagramView server-side events are raised in ImageMap mode.
