Normal Topic Want to know About event during node.move() (Read 3025 times)
Bala
May 14th, 2009 at 11:03am
I have some node in my diagram.When I select some node and press AllignLeft, all nodes shifted to left direction.I want to know Is their any event,which is being called in this process of moving?
I have already tried for Diagram.SelectionMoving,Diagram.SelectionMoved,Diagram.NodeModified,Diagram.Node
StartModifying,Diagram.SelectionChanged event.
The code which I am using to allign left is
node.Move(active.Bounds.X, node.Bounds.Y);
Please suggest.
Bala
Re: Want to know About event during node.move()
Reply #1 - May 14th, 2009 at 1:08pm
There is no event raised by Move. You could call node.SetRect(rect, true) to get NodeModified raised.
Bala
Reply #2 - May 15th, 2009 at 5:54am
Thanks Stoyan,this is helpful for me.
Anshul
Senior Member
Reply #3 - May 15th, 2009 at 8:23am
Hi Stoyo,
I have arranged some nodes in Hierarchical, Compact, Horizontal and Vertical layout.
I want to know about the event which is being fired when I use any one of these.
Bala
Reply #4 - May 15th, 2009 at 8:59am
The layout classes have a LayoutNode delegate property. Assign your method with the same signature to it, and the layout function will call it for each node.
Bala
Reply #5 - May 19th, 2009 at 4:48am
Hi Stoyo,
I am not getting what you wrote.Did you mean by this kind of code?
layeredLayout.LayoutNode = delegate(object sender, NodeEventArgs e){ };
1. Could you please send a snippet of code, showing how to use delegate for each node of Layout?(I want to call NodeModified or any other event through this delegate).
2. After layeredLayout.Arrange(diagram), I want new x,y position of nodes.How can I get it?
Bala
Reply #6 - May 19th, 2009 at 7:38am
1. Add a void LayoutNodeHandler(DiagramNode node, RectangleF oldBounds) { ... } mehod to your class and set layeredLayout.LayoutNode = LayoutNodeHandler.
2. Use DiagramNode.Bounds.X and Y.
