Normal Topic type node (Read 1589 times)
BidMaestro
to learn is to live
type node
May 17th, 2009 at 11:28am
Could not find help on forum for this one and I am guessing you have probably dealt with this before.
I have created a diagram full of shapenodes and have just added my first tablenode. My code loops the collection using a 'for each loop' (vb.net) I used your coding example from the developers help file.
Dim n As DiagramNode
For Each n In Diagram.Nodes
Dim b As ShapeNode = CType(n, ShapeNode)
If Not b Is Nothing Then
End If
Next
However I am obtaining the following error
13 Unable to cast object of type 'MindFusion.Diagramming.TableNode' to type 'MindFusion.Diagramming.ShapeNode'.
Is there an easy way to exclude the tablenode from my 'for each loop' or determine the node type before processing?
I did have success in using the following code to identify a Tablenode
If ChartNodeDN.GetType.ToString = "MindFusion.Diagramming.TableNode" Then
' skip this node
End If
Doug
« Last Edit: May 17th, 2009 at 1:26pm by BidMaestro »
Re: type node
Reply #1 - May 18th, 2009 at 7:28am
Hi Doug,
Try this:
' skip this node
If TypeOf node Is TableNode Then Continue For
BidMaestro
to learn is to live
Re: type node
Reply #2 - May 18th, 2009 at 8:57am
You solution is far more elegant than my dinosaur.
You may wish to consider incorporating your solution in the Developers Guide rather than the Reflection technique.
Thanks again
Doug
