Normal Topic Tablenode Row Select/Highlight (Read 6694 times)
BidMaestro
to learn is to live
May 20th, 2009 at 1:44pm
Similar to other general table controls it would be great if when you clicked on a row it was highlighted. A user would then have confirmation that they clicked on the correct row.
Re: Tablenode Row Select/Highlight
Reply #1 - May 28th, 2009 at 6:47am
Hi Doug,
That looks like a nice feature, we'll implement it in a couple of days.
Reply #2 - May 28th, 2009 at 12:27pm
Hi Doug,
We have added AutoHightlightRows property to Diagram; set it to true, and the cells in the last row clicked by the user will be painted using the RowHighlightBrush. You can get or set the row highlighted in a table using the HighlightedRow property. This is available in the latest v5.3 beta build:
https://mindfusion.eu/_beta/fcnet53.zip
BidMaestro
to learn is to live
Reply #3 - May 28th, 2009 at 12:33pm
you guys are too good; I will test it out over the next day and let you know my thoughts.
Have a great weekend
Doug
Reply #4 - May 28th, 2009 at 1:17pm
unfortunately not as good as we'd like 8) we've already found a null-reference bug happening when you load an older diagram file that didn't have the new properties. This version should fix it:
BidMaestro
to learn is to live
Reply #5 - May 28th, 2009 at 1:35pm
I certainly understand the world of regression testing. we test, we test and we test again.
Have just tested the beta AutoHighlightRows property and it works a treat...well done!
This ensures the user knows what row they clicked on.
I am always happy to test your new features and provide feedback.
Doug
BidMaestro
to learn is to live
Reply #6 - May 28th, 2009 at 1:58pm
Just tested the HighlightedRow property of the tablenode to obtain the row that was clicked and also reset the property under program control to select a different row.....excellent
Doug
