Normal Topic Tablenode - Height & Width property (Read 2455 times)
BidMaestro
to learn is to live
May 20th, 2009 at 1:56pm
It would be useful if the Tablenode had a height & width property that could be read to determine the tablenode dimensions. Additionally altering the values in these properties would readily alter the dimension of the tablenode. Obviously the same ability on shapenodes could also be useful
Re: Tablenode - Height & Width property
Reply #1 - May 28th, 2009 at 6:44am
Hi Doug,
Currently this can be done by checking table.Bounds.Width and table.Bounds.Height. Setting new width and height can be done through the Resize method or by setting Bounds.
