Normal Topic Refreshing of node after some properties changed (Read 1614 times)
MUDO
May 20th, 2009 at 8:58pm
Hi.
I have my own editor for properties of nodes (color, caption,...).
If I change TextColor property of TableNode it changes visually after I click to diagram or perform some action with diagram. I totaly understand why Smiley
Is there any sophisticated way how to refresh only this node from form? Because now Im calling  Me.fcDiagramView.Refresh() but that is not very smart.
Thx.
...MUDO...
Re: Refreshing of node after some properties chang
Reply #1 - May 21st, 2009 at 5:13am
Call diagram.Invalidate(table.GetRepaintRect()). The TextColor setter should do that, but it seems our developer forgot to call the repaint method.
MUDO
Reply #2 - May 21st, 2009 at 6:53am
Hi.
Function GetRepaintRect has parameter includeConnected As Boolean. In help is stated "true if related items should be considered too; otherwise, false." What does it mean "related items"? Attached via AttachTo function?
Thanks for your answer Smiley
...MUDO...
Reply #3 - May 21st, 2009 at 11:08am
Yes, attached nodes and also links connected to the table.
