Normal Topic Containers-size and position (Read 1323 times)
MUDO
May 21st, 2009 at 1:55am
Hi.
1)
I add table to container like this:
Dim LoMMContainerNode As ClsMMContainerNode = OoAction.Data("CONTAINER")
Dim LoMMTableNode As ClsMMTableNode = New ClsMMTableNode(Me.fcDiagram)
Me.fcDiagram.Nodes.Add(LoMMTableNode)
LoMMContainerNode.Add(LoMMTableNode)
LoMMContainerNode has bounds set from constructor -- > (0, 0, 50, 50)
LoMMTableNode has bounds set from constructor -- > (0, 0, 30, 50)
After added table to container, container is in top left corner partially invisible. Is this because container is adapting to tables position?
How to preserve position of container and add table to it?
2) I have node in container and via code Im changing size of node. How to update size of container also? Its size is not changed after resizing a node in container via code.
Thx.
...MUDO...
Re: Containers-size and position
Reply #1 - May 21st, 2009 at 5:17am
1. Try disabling AutoShrink before adding the node.
2. Call ContainerNode.UpdateBounds.
MUDO
Reply #2 - May 21st, 2009 at 7:06am
Hi.
Sub from derived class from ContainerNode:
'adding node to container
    Public Sub AddNodeToContainer(ByRef OoNode As DiagramNode)
        OoNode.Bounds = (New RectangleF(Me.Bounds.Location, OoNode.Bounds.Size))
        Me.Add(OoNode)
        Me.UpdateBounds()
    End Sub
Works perfect. Thaks Stoyo Smiley
...MUDO...
