Normal Topic Minimize intersections of shapes + layouts (Read 1380 times)
Alex.kg
May 21st, 2009 at 8:26am
Is there a way to minimize shape nodes intersections after applying layout objects (especially interested in SpringLayout) ?
Re: Minimize intersections of shapes + layouts
Reply #1 - May 21st, 2009 at 11:35am
You might run only a few iterations of AnnealLayout as a fine-tuning phase, starting with a low InitialTemperature value and with all costs except NodeDistribution set to 0. This should pull nodes apart a bit. Make sure Randomize is disabled and set LayoutArea to diagram.GetContentBounds().
Alex.kg
Reply #2 - May 21st, 2009 at 4:46pm
Thank you for suggestion.
I'll try it and let you know results.
Alex
