Normal Topic How get row and column from tablenode (Read 2179 times)
roberto.bonilla
I'm so Happy
May 25th, 2009 at 2:46am
I new using Diagram component, but i need know how can i get the row and column from origen and destination when start to draw a link.
1. I've 2 tablenode and when i start to draw a link between tablesnode a need get the value in each cell from start and end link
Regards
RB
RB
Re: How get row and column from tablenode
Reply #1 - May 25th, 2009 at 5:11am
Hello Roberto,
You could call table.CellFromPoint to get the cells at the mouse position in LinkCreating event handlers. Alternatively, check the LinkValidationEvenArgs.TableRow property. Once the link has been created, you can use link's OriginIndex and DestinationIndex properties.
roberto.bonilla
I'm so Happy
Reply #2 - May 25th, 2009 at 1:29pm
thanks Stoyan
CellfromPoint have 3 parameter
Public Function CellFromPoint ( _
    point As PointF, _
    ByRef row As Integer, _
    ByRef col As Integer _
) As Boolean
but in the LinkCreated event just i have PointF not the row and column
could put some examples to clarify how to do it please ?
Regard
RB
RB
Reply #3 - May 25th, 2009 at 2:36pm
CellFromPoint is useful only in the validation event handlers. In LinkCreated the link is already connected to some table rows, and you can use its OriginIndex and DestinationIndex properties to get the related rows and loop over their cells.
roberto.bonilla
I'm so Happy
Reply #4 - May 26th, 2009 at 4:20pm
Thanks a Lot  Grin
Finally I did it
Regards
RB  Grin
RB
Reply #5 - May 26th, 2009 at 4:30pm
that's great Grin
