Normal Topic Crash on node drag 1.03 release (Read 4201 times)
jaiswalamit
May 25th, 2009 at 1:53pm
In the released version of 1.03:
I am finding that if I drag a selected node by pressing the left button down on any other area than the "middle" square which is supposed to be for clicked and dragged, then the CRASH occurs.
The exception is raised at:
Mindfusion.Diagrammin.Silverlight.Interaction.Start()
at
Mindfusion.Diagrammin.Silverlight.BehaviorBase.OnMouseMove(Mouse...)
I have my diagram property set as:
AllowInplaceEdit="False"
Behavior="Modify" ; //so that I can drag the nodes
ShowAnchors = ShowAnchors.Selected;
ModificationStart = ModificationStart.SelectedOnly;
Amit
Re: Crash on node drag 1.03 release
Reply #1 - May 25th, 2009 at 2:33pm
Yes, I have reproduced it; our developer will check this tomorrow.
Reply #2 - May 26th, 2009 at 11:22am
Hi Amit,
Please try the version from the PM page.
jaiswalamit
Reply #3 - May 26th, 2009 at 11:37am
Hi Stoyan,
Which is the PM page? Do you mean the trial download link? If yes, then I may try it, but would it start showing me the "Diagram lite Trial ..." caption in the graph area?
Amit
Reply #4 - May 26th, 2009 at 11:38am
Hi Amit,
You should see a "you have X messages" link at the top of this page. Click there...
jaiswalamit
Reply #5 - May 26th, 2009 at 1:22pm
Hi Stoyan,
This fixed the crash - much appreciated.
Thanks a lot,
Amit
James_Thomas
Reply #6 - Jul 28th, 2009 at 7:23am
I get something similar with my diagram
<my:Diagram AlignToGrid="True" Behavior="LinkShapes" AllowInplaceEdit="True"
                                           LinkBrush="Green" ShapeBrush="LightSkyBlue" x:Name="theDiagram"
                                           KeyDown="theDiagram_KeyDown"></my:Diagram>
Every now and again the diagram will cause silverlight to crash with no warning or error message. This always happens when you're beginning to drag a node, but I'm afraid I can't give any more details.
James.
Reply #7 - Jul 28th, 2009 at 9:30am
Hi James,
James_Thomas
Reply #8 - Jul 28th, 2009 at 11:38am
Thanks, I'll give that a go.
James.
