Normal Topic Deleting nodes and links using javascript (Read 1861 times)
choohj70
May 28th, 2009 at 1:32am
How do you delete a node and/or a link on an applet using javascript?
It doesn't seem to have an equivalent of the DiagramNodeCollection that I can use "Remove" to remove a single node from... Same goes for the DiagramLinkCollection.
Is this accurate or am I missing something obvious?
Thank you.
Re: Deleting nodes and links using javascript
Reply #1 - May 28th, 2009 at 7:44am
Call the applet's getDiagram() method to get the Diagram object, and then diagram.getNodes().remove(someNode).
choohj70
Reply #2 - May 28th, 2009 at 4:59pm
Thank you. That worked perfectly.
