Normal Topic Link text placement (Read 1374 times)
jmquinlan
Link text placement
May 28th, 2009 at 3:02pm
Whats the possibility of defining where the bias for the position of the text is. An example would be in a class diagram you have links connecting the classes with a name and qualifier to say 1 to many link. Like in a database diagram.
you need the name position to be biased to one node or the other to indicate more about the relationship. Is this possible? If so whats the magic argument?
e.g.
               *1
{Node1}----------------{Node2}
Re: Link text placement
Reply #1 - May 28th, 2009 at 3:07pm
There is a link label position property in the ActiveX version, we could port it to .NET in a couple of weeks. You might also custom-draw the label by setting link.CustomDraw = Additional and handling the DrawLink event.
jmquinlan
Reply #2 - May 28th, 2009 at 3:15pm
cheers I'll look into it.
regards and thanks
