Normal Topic Nested TableNodes (Read 1032 times)
RodionP
Nested TableNodes
May 28th, 2009 at 7:04pm
I'm trying to insert another TableNode into cell of existing TableNode so that I could collapse my table recursively.
I have a couple of collapsible cells, and I want all the bottom cells to collapse when upper ones get collapsed.
Re: Nested TableNodes
Reply #1 - May 28th, 2009 at 7:18pm
There is no built-in support for table nesting available, but it might be possible to implement something similar with some event handling.
There is a public TableNode.GetSpannedCellRect method in v5.3 that might help in this case:
https://mindfusion.eu/_beta/fcnet53.zip
Set the Bounds property of the nested table to the result of that method and call nestedTable.AttachTo(parentTable). Now if the user moves the parent table, the nested table will move too. Finally, handle the TableSectionCollapsed/Expanded events raised for the parent table to hide or show the nested tables.
