Normal Topic Attach a shapenode to end of linknode. (Read 983 times)
khstar
Jun 2nd, 2009 at 1:33am
Is there a funtion to attach a shapenode to each side of a Linknode?
When I tried to attach a shapenode to a linknode, I just have three options.
To Point, To segment, To logestHsegment..
I can attach shapenodes to start(origin) of linknode easily, however How can I attach shapenodes to end(destination) of linknode?
Re: Attach a shapenode to end of linknode.
Reply #1 - Jun 2nd, 2009 at 5:29am
Use the attach to link point option, specifying the index of the last point, which is link.ControlPoints -1 for the polyline and cascading styles. If using auto routing, you might have to re-attach the node in response to the LinkRouted event, since the routing function might change the number of segments.
