Normal Topic Item Adding functionality (Read 1980 times)
hrumayor
Jun 3rd, 2009 at 2:27pm
I would like to have a ItemAdding so I can do some operations on it before it is added to the items collection is there a way to do this?
At this point I am using ItemAdded, what I want to do is generate a unique identifier and to do that I want to make some enforcements because the item gets added before I can do this check I have to filter it first it would be nice if I got a pre addition event to handle this type of functionally.
Hugo
Re: Item Adding functionality
Reply #1 - Jun 3rd, 2009 at 2:42pm
Do you want it to be a validation event that can be cancelled?
hrumayor
Reply #2 - Jun 3rd, 2009 at 6:02pm
Yes that would be OK, it is more like adding the final construction step depending on what is already on the items. but a validation event would be good, it you don't need the cancellation simply you don't set it. I am emulating the event by ignoring the node that got inserted.
eg.
void OnItemAdded(object sender, ItemEventArgs e)
if (e.Item is WidgetBase)
var widget = (WidgetBase)e.Item;
var widgets = Nodes.Cast<WidgetBase>()
.Where(w => w != widget);
if (widget.Id < 0)
widget.Id = widgets.FirstOrDefault() == null ? 0 : widgets.Max(s => s.Id) + 1;
Reply #3 - Jun 3rd, 2009 at 6:29pm
It seems the collection classes raise some internal events when adding items in order to synchronize with other collections (e.g. diag.Items.Add also adds to diag.Nodes), and this happens before the item is actually added. We'll consider making them public, or otherwise add a new event for this purpose.
