Normal Topic the link in the center of the node (Read 1003 times)
Hamdy Ghanem
Jun 6th, 2009 at 9:45am
I have a class inherited from shape node
when i make a link between two nodes
the link begin from the center of the node to the center of the other
what property i missed to make the link only from the edge of the node not in the center
[img]http://hamdy.ghanem.googlepages.com/diagram.PNG[/img]
Re: the link in the center of the node
Reply #1 - Jun 7th, 2009 at 8:21am
Have these links been drawn by hand or created programmatically? Does you class override any methods of the base ShapeNode? In such a case, make sure you call the base implementation, or otherwise the code that aligns the links might not be executed. Also, does your class set the AnchorPattern or Shape properties?
