Normal Topic Problem during DiagramMouseWheel (Read 1574 times)
Bala
Jun 8th, 2009 at 2:09pm
Hi Stoyan,
I have sent a sample application to your support mail id, please have a look into that.
Problem :-
When MouseWheel over the diagram, I want to perform zooming. Zooming should be performed at the current location of mouse point. It is working well when my diagram captures whole screen. In this time if my mouse position is suppose (250,250),so zooming is performed by this position(This mouse position becomes center for zooming). Its good this is that which I want.
Now if I have divided screen into two parts and half of the part of screen has diagram. when I go for zooming in this diagram, diagram shifted some ward up and down position which has no relation with mouse position.
Please help us to solve this problem.
Bala
Re: Problem during DiagramMouseWheel
Reply #1 - Jun 9th, 2009 at 5:36am
The 'Parent' reference in your code refers to the window's Parent, which is null. It works better if you replace it with diagram.Parent, for example:
Point point = e.GetPosition(Parent as Diagram);
becomes
Point point = e.GetPosition(diagram.Parent as ScrollViewer);
and a few lines below
Point newcurpos = diagram.ClientToDoc(e.GetPosition(Parent as ScrollViewer));
becomes
Point newcurpos = diagram.ClientToDoc(e.GetPosition(diagram.Parent as ScrollViewer));
Do the same in the if (e.Delta < 0) case.
Bala
Reply #2 - Jun 9th, 2009 at 5:46am
Many thanks stoyan,its working Smiley
