Normal Topic Overlapping link arrowhead with connected shape (Read 2418 times)
hrobert
Jun 12th, 2009 at 9:36am
I am trying to create a link whose end arrow head will overlap the border of the shape to which it connects. This is a screenshot of what I would like to achieve.
It looks like the normal behavior is that the link arrow head never goes beyond the intersection/anchor point. Does anybody know a way I could achieve that?
Thanks in advance,
Robert
Re: Overlapping link arrowhead with connected shap
Reply #1 - Jun 12th, 2009 at 9:54am
At this time you can't change the position of the arrowhead shapes. You could set HeadShape = None, CustomDraw = Additional, and handle the DrawLink event to draw a shape at the position of the last point in e.Link.ControlPoints.
hrobert
Reply #2 - Jun 12th, 2009 at 12:52pm
Thanks for your solution. That works really ok.
If I would like to have that arrowending appear also while user is drawing the link I think I need to create a custom link inherited from DiagramLink and override the Draw method. Am I right? I got this idea from the Fishbone sample. Or is it also another solution?
Thanks a lot,
Robert
Reply #3 - Jun 12th, 2009 at 1:24pm
Custom drawing should work also while creating new links. You could handle the InitializeLink event to initialize the properties of a new link when the use starts drawing it.
