Normal Topic How to trigger the node double click? (Read 20559 times)
mazelin
Jun 17th, 2009 at 4:24am
thanks!
Re: How to trigger the node double click?
Reply #1 - Jun 17th, 2009 at 5:44am
Do you mean you need to call your NodeDoubleClicked event handler method? Or enter in-place edit mode from code?
mazelin
Reply #2 - Jun 17th, 2009 at 12:13pm
I need to call NodeDoubleClicked event handler method.
mazelin
Reply #3 - Jun 17th, 2009 at 12:29pm
Thank you! I find it.
Praba
Reply #4 - Sep 11th, 2009 at 11:37am
Hi
Can you please explain how you have solved this problem of invoking double click event.
Regards
Praba
Reply #5 - Sep 11th, 2009 at 12:57pm
You cannot trigger the event from code, but you can call your event hanlder method. E.g. from some other handler call OnNodeClicked(null, new NodeEventArgs(someNode)).
reshma
Reply #6 - Jan 16th, 2018 at 12:05pm
I have same issue with node double click can you please explain me if any one have solved it
Reply #7 - Jan 16th, 2018 at 1:10pm
I can see a public void RaiseDoubleClicked(DiagramItem item, Point mousePosition, MouseButton mouseButton) method in Diagram class that will let you raise the event. If you are looking for a way to start in-place edit operation, call the Diagram.BeginEdit method instead.
reshma
Reply #8 - Jan 17th, 2018 at 5:44am
No,i want show detail page on double click of node
Reply #9 - Jan 17th, 2018 at 7:09am
Just handle the NodeDoubleClicked event, doesn't it fire for you? An event handler is shown in SiteMap sample project, opening a details dialog when you double click a node.
