Normal Topic remove grids when export as pdf (Read 2802 times)
khstar
Jun 18th, 2009 at 6:31am
Hi
How can I remove grids when export as pdf?
I tried enablebackground=false,
however it doesn't work.
If there's not that option, I think making this option will helpful to another users;
Re: remove grids when export as pdf
Reply #1 - Jun 18th, 2009 at 7:43am
You could set ShowGrid = false temporarily before exporting. We'll add some property to PdfExporter in the 5.3.1 release.
khstar
Reply #2 - Jun 18th, 2009 at 11:34pm
I forgot that way..;;
Showgrid=false works well.
But, I got another problems.
1st, Korean doesn't show up in export, thought I tried every options of DefaultEncoding
2nd, the fonts applied to tablenodes were not valid for PDF export.
I always appreciate your supports.
Reply #3 - Jun 19th, 2009 at 6:40am
Korean character encoding is not supported yet by PdfExporter. We'll try to implement it in the 5.3.1 release.
Reply #4 - Jun 29th, 2009 at 7:09am
Could you email to support@mindfusion.eu a sample diagram xml file with some Korean texts?
