Normal Topic Routing with Two Way Links (Read 3134 times)
Aziz ur Rahman
Jun 18th, 2009 at 8:17am
u want to layout a diagram in which two nodes can have two or more links between them. Currently If i use any of the layout now, it will overlap the links. Is there any property i can set and use a particular layout algo. Check the picture below. It is the kind of result i want.
http://weblogs.com.pk/photos/aziz/images/168078/original.aspx
Syed Aziz ur Rahman
Re: Routing with Two Way Links
Reply #1 - Jun 18th, 2009 at 9:28am
Copy the code from the event handler here to a method, and call it for all link pairs:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=122711142...
Aziz ur Rahman
Reply #2 - Aug 11th, 2009 at 1:32pm
Dear Stoyo,
The solution you provide may work for a normal view but when i am trying it on 3D view, it is not working.
I have tried setting the style property of the links to Bezier but it did not help as well.
2) The link created event is not getting fired when i am creating a link programmatically in 3D view.
Can you please check and propose some other solution.
Syed Aziz ur Rahman
Reply #3 - Aug 13th, 2009 at 4:00pm
Hi Aziz,
Links in the 3D view are always drawn as straight lines between the 3D coordinates of the nodes they connect. We'll see if we can add some support for 3D Bezier curves. At this time you might try setting a Pen that draws two lines when you detect a double link; the MoleculeViewer example shows how to do that by setting the CompoundArray property of the "twoLinks" pen.
