Normal Topic Pdf export / colors (Read 1661 times)
dku
Pdf export / colors
Jun 19th, 2009 at 2:51pm
We are using the PdfExporter to extract a Pdf file from our diagram. But, our diagram has a dark background color and the writing has white fonts.
In the Pdf, we certainly don't want a dark background (it is ok - white), but the writing has to be put to something dark, it is remaining in white (not visible).
It seems that the same colors ares used for screen and for PDF export.
Any solution ? Ideally 2 different color palette (sytling/templating or other).
Thanks for your help
Bye
Didier
Re: Pdf export / colors
Reply #1 - Jun 22nd, 2009 at 5:54am
You will have to do this the old-fashioned way by looping over the links and changing the color of each one. We'll add some support for styles in the 2.2.1 release.
dku
Reply #2 - Jun 22nd, 2009 at 3:36pm
Thanks, it will be nice.
Bye
Didier
