Normal Topic Drawcontrol Behaviour (Read 2377 times)
zoozoo
Jun 24th, 2009 at 2:33am
Please can anyone explain the way draw control behaviour and control node has to be used.
I am trying to create a diagram with controlnodes but everytime i try creating the controlnode it throws an exception
code snippet
diagram.Behavior = Behavior.DrawControls;
diagram.DefaultControlType = typeof( System.Windows.Controls.TextBox) ;
TextBox tb = new TextBox();
tb.Text = "test";
ControlNode cntrl = new ControlNode(diagram, tb);
var layout = new MindFusion.Diagramming.Silverlight.Layout.TreeLayout();
layout.Arrange(diagram);
thanks in advance
Re: Drawcontrol Behaviour
Reply #1 - Jun 24th, 2009 at 6:21am
I could not get this code to crash, nor calling layout.Arrange crashed after drawing some nodes. Could you copy the stack trace here?
zoozoo
Reply #2 - Jun 25th, 2009 at 4:35am
Sorry for replying late
heres the stack trace
System.NullReferenceException was unhandled by user code
  Message="Object reference not set to an instance of an object."
  StackTrace:
      at MindFusion.Diagramming.Silverlight.DiagramNode.AddExpandButton()
      at MindFusion.Diagramming.Silverlight.DiagramNode.set_Expandable(Boolean value)
      at MindFusion.Diagramming.Silverlight.DiagramNode..ctor(Diagram parent)
      at MindFusion.Diagramming.Silverlight.ControlNode..ctor(Diagram parent, FrameworkElement control)
      at TreeLayout.Page.OnPageLoaded(Object sender, RoutedEventArgs e)
      at System.Windows.CoreInvokeHandler.InvokeEventHandler(Int32 typeIndex, Delegate handlerDelegate, Object sender, Object args)
      at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, String eventName)
  InnerException:
thanks in advance.
Reply #3 - Jun 25th, 2009 at 6:21am
Seems that's a bug in adding the +/- icon from the ControlNode constructor when Diagram.NodesExpandable is set. As a workaround, set NodesExpandable = false, and for each node set Expandable = true after adding it:
diagram.NodesExpandable = false;
for (int i = 0; i < 10; ++i)
	var node = new ControlNode(diagram, new TextBox());
	diagram.Nodes.Add(node);
	node.Expandable = true;
